1 - 14 of 14 Posts
Doing a kitchen remodel where I have to move the microwave to another wall. The outlets are wired with #12 on a 20A breaker.
Here is my dilemma. Can I run a #14 from from the microwave to one the #12 outlets to run the microwave?
Fridge and stove are on a separate circuit so the only thing on this 20A is the kitchen receptacles and lights.
Thank you in advance and Merry Christmas!
The #14 would be branched off of one of the #12 outlets and will only power the permanently mounted microwave. Here are the specs for the microwave:
Product rated at 120v, 60 hertz, 15 amps and 1.70 kw. The power supply cord should be connected to a separate 15 to 20 ampre branch circuit single grounded outlet.
Resi EC
You need a dedicated circuit for this appliance.
Do not run #14 on a 20a circuit
Idiot Emeritus
Either a 15 or 20 amp circuit is code compliant. It needs to be a single receptacle, and the amp rating of the receptacle must match the amp rating of the breaker supplying it.
If it's a 15 amp breaker, #14 will be ok. If it's a 20, you'll need #12.
The only places that you can use #14 on a 20 amp circuit is a motor, welder, or HVAC unit.
Rob
Semi-Pro Electro-Geek
I think you cant run a #14 from the microwave to one the #12 outlets to run the microwave You should consult your user guide book to avoid experiments and loss.
It's kind of hacky, but there's no reason he can't. It's code compliant and safe as long as the breaker is 15A. It doesn't even violate the manufacturer's instructions, since they say the microwave "should" be connected to a dedicated circuit, not that it "must". It's just a recommendation.
Reactions: TTW and sqzdog
If there is #14 wire anywhere in the circuit, you must use a 15 amp breaker. Not recommended, but done. Also at the panel, the wire should be marked 15 amp only.
1 - 14 of 14 Posts
