HI'
When you vent a microwave to the outside the advice is to use a 31/4"x10"x6" stack boot.It seems the way the boot is made that the flap from the microwave damper hits the sides of the boot when you turn on the fan not allowing for full opening of the flap, maybe it will open a little less than halfway .If you bend the corners of the flap quite a bit then it will allow for full opening .Is this a usual practice to bent the flap or not ? Also it seems if you use a 4"x10"x6" register boot instead there is plenty of room to allow for full opening . Let me know your thoughts on this .
Thanks
Thanks
