We just moved into an old (1950) house that has some obvious DIY wiring from the previous owner, but everything appears to be in working order.
We purchased a microwave/hood combo (Whirlpool Gold GMH3174 - 1000w hood combo).
The contractor that fixed up our kitchen sheet rock & cabinets moved an outlet up from a lower position on the wall for this microwave/hood. When I hung the unit and attempted to plug it in, sparks flew and the ground prong blackened/melted a bit on the tip. At this time, one circuit breaker flipped, but not the one (assumed) that the microwave is hooked up to, but a 15 amp breaker that handles the living room and bedroom lights and outlets. Only the ground prong of the 3-prong plug actually made it into the receptacle when this happened.
Here is where it gets weird.
We have used our regular counter top microwave plugged into this outlet without incident for 4 weeks. I started asking around to trouble shoot the problem. I tried plugging the new unit into a known, grounded, home run outlet with its own 15 amp with nothing else on it breaker. Same thing: sparks fly, ground prong melted a bit and the breaker for the living room flipped, but not the one I was plugged into.
Blame the microwave, plug in the old microwave an use it for two weeks without incident, take the new microwave back and order another new one.
Now it gets weirder.
New microwave arrives, so I plug it in FIRST to the known, grounded by-itself home run outlet. No problem, no sparks; must be fine. Hang it, bolt it, plug it into the other outlet: SPARKS, MELTED PRONG, OTHER BREAKER FLIPS...just like before. Huh. Immediately I plug the microwave back into the by-itself outlet, and the same sparks and other breaker tripped. Huh.
No extension cords are used, and the outlets are fairly new as well as the wiring. That I can see inside the box.
I can assume that the microwave got screwed up somehow, or at least the cord since it worked in the by-itself outlet first. The microwave/hood unit is "plug & play" , all sealed up and there are no switches to change the voltage. I checked the breaker box an there does not seem to be any thing run 220 or improperly connected, but I can honestly say I have no idea what is going on in the wall or attic, nor can I access either in that area.
What really gets me is that my other microwave (5 year old panasonic 1000w) was plugged into the other outlet and used for weeks, even between incidents.
More weird:
I had my voltage detector out; the suspect outled does not set it off, but the new unit, unplugged and just hanging there, seems to make it beep as if it is electrically live. The only breaker that went off was the 15 amp living room lights breaker. I tried th short the suspect receptacle with a curve of wire and it also sparked, melted and shot firey wads of molten copper towards my face, but did not flip a breaker.
I am a amateur DIY-er, and appreciate any advice that only ends in "call a pro."
The GF's dad is pretty sharp, and has helped on some other issued, but he is baffled by the scenario.
thanks
More weird:
thanks
