Depending on the age of your house and location, the code may have said, if it is a newer build, that that plastic sheet and pipe ran around the outside when it was built. It, the pipe may go to a Sump Pump in the basement. If you have an older home, you could rip up the floor inside the house, about 18 inches from all outside walls, so they can put the pipe on the inside of the house, then run that to a Sump Pump in one of the corners of the house. There are many ways to waterproof a house, watch a few of Mike Holmes Shows he has made in the last decade or so and you will see the various ways they repair leaks.
As I type this I have 2 Sump Pump going at about 10 second intervals and I still have water coming up through the floor!
The Grand River is about a block and 3/4 away from my house, it was a former swamp area it and every house on this street was built on, and since we had all the warm weather, then a 5 inch snowfall and know it is slowly melting, we have the situation I am in.
