Hello,
I have a couple of quick questions for the NEC experts out there. I think they are easy but I would like affirmation. The scenario is wiring of (nominal) 4" x 2-1/8" metal octagon boxes used as "both" junction box and for a porcelain lamp holder in a typical basement application. This box has a volume of 21.5 cu. in., and the box has from the factory internal NM clamps (which I understand to occupy 1 conductor's worth of fill volume) and their associated knockouts, as well as 1/2" and 3/4" knockouts. Based on 14 AWG used in the box, the maximum allowable conductors would be 10.
1. Are the pigtail wires from the Porcelain lamp holder itself counted when computing fill volume for the box? I think the answer to this question is no, as the porcelain lamp holder is in essence a junction box cover, and the pigtails do not enter/leave the box.
2. Does the lamp holder count in fill volume at all? There is no hickey, no stud. Again I think the answer is no.
3. If necessary to meet fill volume requirements, can the factory installed NM clamps be removed and the 1/2" knockouts used in conjunction with an "add-on" clamp such as the 3/8" Halex NM clamp? I understand this type of clamp is not counted when computing fill volume. (I'd post a link to which clamp I'm thinking of but I don't have that privilege based on this being my first post). I am guessing that the answer to 3 is yes.
I understand that any open but unoccupied knockouts must be covered.
Thanks
Thanks
