So I'm a DIYer renovating my house with a tricky thermostat wiring issue that I KNOW should be theoretically possible, but I'm having difficulty figuring out the last steps.
For Context: My house is a single story manufactured home that has forced air heating and cooling. I replaced the thermostat with a Nest 3rd Gen Learning Thermostat, which works perfectly fine.
I then decided to replace the carpet in my living/dining room with hardwood floors (an area that covers ~70% of my house), and while doing so I installed radiant heating via electric panels. I used a RC840T switching relay so that my Nest thermostat could control the radiant heat. This also works perfectly fine.
So independently, both systems can be controlled by a Nest Thermostat. But my goal is to get them both together working under a SINGLE thermostat, treating the heating systems as a Two Stage (something known as Hybrid Radiant Heating). My problem is trying to figure out how to resolve wiring them together. This seems to be a situation that will require an Isolation Relay, but I'm still not sure how to resolve this.
Any help that could be provided would be appreciated. Worst case scenario would require me to have 2 separate thermostats, which is what I'm REALLY trying to avoid.
