I have 6 light poles with mercury vapor lamps and 2 switches mounted to a gate pole that controlls the lamps. The switches are very old and one literally fell apart last night. I replaced both switches which were double pole types rated at 15 and 20 amperes, 120 volts. Now one switch will light the first two poles ( as it did originally ), but everytime I flip the second switch I blow two 30 amp ( ganged together ) breakers. My question: Does it take some kind of special switch to ignite or light the 4 remaining lamps? The old switch was a toggle type,but when it fell apart I found a spring and a ball bearing next to it. Was this some type of momenary contact switch? Help!!! And yes, I double checked the wiring and even took pictures before disassemble to make sure I rewired the new switches correctly.
Note: There are two jumpers connecting the two switches, but I don't know their purpose.
