How do I go about measuring my existing window to install a replacement? Thanks
Thanks you! Not sure if we want to remove the siding....whatever is best and possibly easiest.Bud9051 said:Hi lucky. Some terminology first. The two choices are new construction or replacement. The difference is, new construction fastens to the sheathing beside the window opening and then the flashing, trim and siding go up against the new window. A replacement window fits inside the existing window frame so the trim on the inside and outside remains in place. An up and down window is called a single or double hung. A side by side window is called a slider. Now, since your current window has already been replaced, we don't know if it was inserted into the existing (old) window frame or is they removed the siding and installed a new construction version. What type of siding do you have and are you thinking of removing the siding around the window to facilitate this replacement? Bud
Friend of mine but I'd like to measure and order. What's the best way to measure? ThanksBud9051 said:Replacement windows are the easiest and they are measured and made to fit. Do you plan on installing these yourself or having it done? Bid
