sounds like the tub seal is starting to leak. It will get much worse. Your looking at about a $200.00 repair.
not really an easy repair, a few specialty tools are required also. First lets make sure it is the tub seal. Take off the front panel and look at the underside of the wash tub, right in the middle where the transmission goes into the tub you will find the tub seal. Run the machine to see if the water is dripping down from that seal. Generally the larger the load the more it will leak.Both my husband and I are relatively handy. Is this a repair that we could do ourselves with some internet instruction?
or are we asking for trouble?
Thanks
