So I bought a Maytag Performa side by side Model number PSD65LGES.
It works great however I was left to hook it the water myself.
There are two hook up spots on the back.
one is a plastic tube with a connector on it that obviously goes up towards the water filter and the other hook up is an elbow copper valve. in the lower left hand corner on the back. (this is what I think of as a typical hookup spot)
Here is what I tried. I hooked the water into the elbow copper valve and after waiting several hours nothing, no water, no ice.
So I tried hooking up the plastic tube instead and when I turned on the water it came pouring out the elbow copper valve.
So I put a cap on the elbow copper valve and have the water going into the plastic tubing, but after several hours still no water, no ice.
I can hear the fridge every hour or so trying to get water, but alas I am out of ideas.
Do I need to have both hooked up? They are obviously somehow connected as water flowed from the plastic tubing into the water filter and out the elbow pipe. Curiously the reverse did not happen. Any ideas or help would be appreciated.
