I am renovating a bathroom and looking for help 'mating' my tile to my new fibreglass shower pan. Here is where I am at currently. I have framed, roughed in the plumbing and hung the concrete backerboard and drywall. I am about to start mudding the drywall and putting thinset on the concreteboard seams and corners. I am looking ahead to how I join the tile/grout/thinset at the bottom of the wall, where it meets the fibreglass shower pan.
The concrete backerboard is hung and measures 5/8" from the finished horizontal flange of the shower pan. The vertical flange of the shower pan extends up behind the backerboard. I sealed between the showerpan and framing and also between the concreteboard and the vertical flange on the shower pan with a bead of silicone.
Now I want to fill and seal that 5/8" gap from the bottom of the backerboard and the shower pan. Do I use thinset when I seal the seams and corners? Fill the space with thinset (1/2" backerboard thickness) and and finish it with a layer of grout over top? Do I just leave it as is until after and fill the space entirely with grout?
My instinct is to partially fill with thinset (say 1/4" thickness) and then after tiling I can finish it with grout over the thinset, to match thickness of the grout in the groutlines.
I then assume that I seal the grout and all is waterproof. What about a bead of silicone where the grout meets the showerpan? I dont' think this will look great and not sure if would be necessary.
Any help is appreciated!
thx in advance.
thx in advance.
