1 - 2 of 2 Posts
we are about to install dentil molding, but we do not know how to cut the molding to match the teeth. does anyone have some tips on how to do this.
we are actually only do 2 inside cuts on 2 corners and an end corner.
most of the time you can only make the outside corners line up and inside corners don't
you would would what to divide dental block on outside corner exactly in half first them measure and cut inside next. note the width of dental on inside corner ,cut the piece that will butt the same width
this works until you get to another outside corner then you should make the outside match and let the difference be on the inside corner it's less noticeable
1 - 2 of 2 Posts
