Can someone help me i have 3 rooms and i want to control the light in tthose 3 rooms from the master bedroom. Anyone know what kind of switch i need for the master switch?
i want it so when i turn the master switch on all the lights turn on and disable all the normal switches wth the lights.Any normal light switch will do the job if the lights are all on the same circuit.
Each room has a single pole with its coresponding luminare. I want to put a master switch in the master bedroom to bypass the switch in the other three rooms and turn the lights on.Maybe I'm not following you but it sounds like a code violation. Each room needs to have a light switch in the room it serves. You can put additional switches wherever you want but I don't believe you're allowed to bypass the switch to the room it serves.
Not true. Switch locations are not referenced by the code. A bedroom switch could be anywhere. Not too practical or sensible but possible.Maybe I'm not following you but it sounds like a code violation. Each room needs to have a light switch in the room it serves. You can put additional switches wherever you want but I don't believe you're allowed to bypass the switch to the room it serves.
Once you connect all the lights together for the master to turn them on any one of the switches will turn them all on also. The hots still remain connected to each other when off.When the master is closed, or turned on, the light in each room can't be turned off. When the master is open, each room works as any normal house.
Can i see that line diagram? I think joed is right if you terminate all of the load side together you cant turn on each light with its coresponding switchYou'll need an extra wire from the master room to each bedroom. This wire will come off the load side of a single pole single throw switch. In each room, it will terminate on a brass screw of a three way switch. The other brass screw of each three way switch will get line voltage. The black screw of each three way switch will go to the light in that room.
This is a very odd request BTW. Horticulture?
I'll post a crude line diagram if interested.
The only way to do is with relay system so the hots stay separated or with a 3 pole master switch which will also keep the hots separate when off.
