I've recently finished up remodeling my master bath, from a tight 4x6 to a 11x7.
Had to replace some rotten 1x6 tg plank. Cut out the section that was rotted and replaced it with OSB @ 3/4, then laid a 1/2 sanded plywood down and now I'm ready to start laying the hardi or cement board then tile.
I'v heard some mixed reviews about the application techniques used for this job.
One guy says "use sanded ply of the floor, lay your mastic then tile it, the shower you could use either cement board or hardi then tile." "if you use cement board on th floor the sanded ply will wick and rot"
Another says, "lay hardi on the floor and durock in the shower."
Can someone as another "professional/real world tested" method share ther experiences with this?
What's the right answer? Any help would be appreciated!:thumbup:
