Hello Guys,
Trying to find a solution and stumbled across this website and thought to ask your all opinion to my problem
The tile guy did not do the right thing and his insurance is not covering his mess.
Tile: Crème Marfel Marble 18x18 (resin backed tile)
Areas: Foyer/dining room and the hallway (approx. 800 sq/ft)
Floor: Wood subfloor with single 3/8th OSB :vs_mad:
Floor Prep: Ditra with unmodified thin-set underneath the tile (did not use epoxy based thin set)
Problem: mainly grout cracking and few lose tiles. When we removed few tiles, there was nothing on the back of the tiles, they were clean
House: we just built this house
Floor Joists: 16 OC
Question:
I know I would have to use the right thin-set (epoxy based) and for that, I would have to take the tiles off but is there anything I can do to avoid removing the ditra and adding a second layer of plywood?
Can I strengthen the sub-floor from the bottom I,e the basement ceiling?
If I do have to remove the ditra, can I do concrete board instead and install marble on top of that, the tile store says YES?
Help greatly appreciated.
Thanks
Floor Joists: 16 OC
Question:
Thanks
