I have seen the pro's make a wood filler from sanding dust mixed with what I think was some poly floor finish. They then applied it over all of the floor to fill the gaps.
I have cked the home improvement stores and there appears to be nothing suitable for this on their shelves.
Is this the way it is done? Can I use the waterbased poly or only the urtahane used as a mixer?
The floor I am going to do is 60 years old and suffers from gaps.
i have never seen it done with poly. If i have a small hole or 2 to fill i will make my own with saw dust and glue. If it is a big gap it will not look good though. Only tiny pencil line gaps.
There is a way you can make these gaps alittle better. You can cut slivers to glue into gaps. It is best if you have good carpentry skills. If you have access to a table saw follow the following steps. Use peices of your flooring to do this. Or, you can use any peice of wood of the same kind. Set the blade of the table saw to 7 degrees. Set the fence so that you only cut a sliver the thickness of the 3/4" hight of the wood. Flip the wood over and set the blade to 0 derees. Keep flipping and changing back to 7 degrees until you have more peices than you need.
To install these slivers cut them to length, add glue to both sides, and put the peice in the crack. Tap it lightly with a hammer. Use a utility knife and score the sliver lightly on both sides. It will then break off easily. When the glue sets up you can sand and stain to your liking. You can then put poly on to match the finish of the floor you have. Try one spot first to make sure you like this. Don't forget to tape on both sides of the sliver to make sure the poly does not go onto the finished wood.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
DIY Home Improvement Forum
