Hi,
We just had our bathroom renovated. Everything was gutted down to the studs.
Evidently the room is slightly out of square and the walls are slightly out of plumb.
This has caused some slight gaps in the molding around the window as well as the vanity and some slight unevenness on the baseboard molding.
The house is about 50 years old and I understand that houses settle but in such a gut renovation such as this, should the contractor be taking corrective action to make sure that the room will be plumb and square?
They just installed drywall directly to the existing wall studs. My thought was that they could have used shims and drilled the drywall through the shims and into the stud to make it plumb. Just the same way that you would use shims when installing a door or window frame.
Is this something that needs to be requested specifically or should the contractor have done this on his own?
Thanks
Thanks
