I have the old 2 conductor wire with no ground on some of my circuits.
I installed a few GFCI's on some recepticals and now find that an upstairs ceiling light does not work. I may have reversed a hot and neutral but I am not sure as the conductors cannot be identified. So to check my connections, I need to make a ground by connecting a separate single conductor to a cold water pipe, radiator or to a receptical that has a ground so that I can test with my volt meter as to which wires are hot.
I tried to be careful and not mix up the connections but it must have happened. What do you think?
