Hello all, great forum, tons of information here.
I'm going to be fixing up a 20' x 12' garage, and I was wondering what size of floor joists that I should use. Right now, there is a dirt floor, and I was initially looking at pouring concrete, but I think that I'll go with a wood floor instead.
Some more info: I live in Canada, so we do get cold winters and our recommended footing depth is 4ft. The shed is sitting on a concrete block foundation that appears to be just placed on the ground. My plan is to dig out the shed enough so that the joists could be fastened to a ledger on the inside of the concrete blocks, and have the level of the joists with plywood on top even with the top of the concrete block.
My basic plan is to run a water line underground from the house to the shed, and insulate the floor, walls etc so that it can be used year round.
So, if anyone could answer a couple of questions, that would be great:
1. What size floor joists should I use? is 2x6 minimum? I was planning on pouring a few concrete footings running up the middle of the shed that will support a beam for the joists to rest on. So that way, the maximum span without support would be about 6'.
2. Can I simply insulate the floor and put some sort of strapping underneath the joists so the insulation won't fall out? Is there another, better/easier way to insulate a floor?
Anyways, I'll stop there, and see how things go for now. I've been doing a lot of reading, but there are still many things that I'll need to know as this project gets going.
Thanks a lot for any help/advice/opinions anyone is able to give me.
