I've got a full slate of 30 full size breakers in my 42 circuit QO Square D panel. I want to convert some to tandem breakers so I can add 4 new circuits from a remodeled bathroom. Do I have the same number of amperage/breaker values on each bus?
X2. You are not allowed tandems in that panel.if you have a 42 circuit panel it is almost certainly not allowed to have tandem breakers
Breaker panels made by the same manufacturer use common breakers. A 20/40 panel made by the same manufacturer will use the same breakers including tandems.They just happen to fit in the panel you have.Why do they make tandems for it then?
Only the bottom 5 slots.Do the tandems need to go only in the bottom spaces or can I combine some circuits into tandems in the top?
