ok...have a question re the ground between the main panel and the disconnect.
300 amp Service grounded to to UFER (Concreate Encased Ground) with #4 AWG solid Copper.
Off the meter base is a 200 amp disconnect (House)and a 125 disconnect (Shop) Both disconnects have the bonding screws installed.
The 200 amp disconnect is fed from the meter 2 hot 1 neutral, all 2/0 CU THHN.
From the 200 Amp House disconnect it feeds through the wall in conduit to 200 amp panel with a 200 amp Main breaker. It is connected right now to the outside disconnect with the three wire 2 hot 1 neutral 2/0 CU THHN. No ground wire in the pipe. The main panel does have the neutral and ground buss bonded.
The 125 Amp disconnect is fed from the meter 2 hot 1 neutral, All 1/0 CU THHN. No panel feed yet.
So my Question is....Should the 200 AMP main panel be un bonded and a ground wire ran to the 200 AMP disconnect outside the house.
I have attached pictures to hopefully visualize the setup. THANKS FOR THE HELP!!!!
