Current setup:
125 amp main breaker disconnect outside next to the meter box
It feeds a panel that does not have a main breaker.
Replacement system:
200 amp exterior panel with feed through
Same 125 amp panel inside
The feed through wires will feed the panel inside. Does there need to be a separate 125 amp breaker to the panel. The same gauge wire will be going from the feed through lugs to the main panel.
Replacement system:
