Hi all,
I'm trying to decide on the best approach for some soundproofing between my two floors.
The lower floor ceiling currently has Green Glue sandwiched between a 1/2" and 5/8" sheet drywall. I'd like to take it a step further.
The upper floor will be getting a complete overhaul, including flooring. I considered lifting the subfloor (T+G OSB) and stuffing some Roxull in there...but that's a lot of work, and I'm not sure how easily the T+G will come up.
My next idea was putting down a 1/4" of cork underlay, then 1/4 SurePly plywood underlayment, then put the 7mm Vinyl Planks on top.
I understand that most manufacturers want vinyl planks to be installed on a solid surface, which is why i'm thinking 1/4" plywood on top of the 1/4" cork.
These are the products i'm thinking of stacking:
Cork Underlay
SurePly (stapled down)
LifeProof Planks
Thoughts?
Cork Underlay
LifeProof Planks
Thoughts?
