Hi all,
I have a 8' bearing wall in my basement I want to open up as I work on finishing it. I had a structural engineer draw up plans. For the 12' opening, he indicated (3) 11 7/8 LVL beams.
There's a tradesman in our neighborhood that worked on the exact same model house as mine and did the same work. When I spoke with him about doing the work, he indicated three LVL manufacturers and one engineer indicated the LVLs wouldn't support the mid-span point load and recommended a steel beam on that house. That's what he went with.
I don't mean to question a PE's work, but the conversation introduced a slight bit of concern. I thought I'd try here to see if my concerns are misplaced and I should just go with what the engineer indicates or if I should reconsider and go with steel. The difference in cost is about $1k for T&M, but I'm willing to spend it if needed.
Attached are pictures showing the full wall, as well as the squash block where the point load transfers from the floor above. There is no snow load on this wall, according to the engineer (he looked in my attic).
Thanks for any thoughts you have.
