Obviously he's wanting to do this on the cheap...It's only a shed.Why would you not first sheath the wall, wrap with house wrap then side it?
Let in braces.What's to stop the wall from racking if there's no sheathing?
yeah, 3/8 is thin. thats why i'm asking.It can be used on a shed. 3/8 is pretty thin though, even thinner on the groved portion. If you want to go directly over the studs 16"oc is the max spacing. Personally, I wouldn't use it.
i have 2 buildings, house and garage, that are vinyl sided. i want a contrast.Why would you not first sheath the wall, wrap with house wrap then side it?
bingoObviously he's wanting to do this on the cheap...It's only a shed.
Let in braces.
Ya, that would add about 5 min a wall. :whistling2:i don't want to do that. way to much work. is there any other way ?
Plywood bracing inside or outside, either will work fine.oh. the rear and garage side, they are not going to be seen. so i was planning on 1/2 AC2 plywood .
also. the inside is going to have a lot of built in shelving = 2x4's and plywood screwed to the walls.
think this would add enough rigidity to be able to use the 3/8 SS on the other 2 sides ?
that guy looks to be framing a 2x6 wall. would the in let brace detract from structural integrity when done to a 2x4 wall ?
Nope...and it doesn't need to be a 1x6 either. A 1x4 will work just fine.that guy looks to be framing a 2x6 wall. would the in let brace detract from structural integrity when done to a 2x4 wall ?
