Hey I have lp ruud furnance that will not light. I have a call for heat, the inducer motor starts I am getting 24V out of the centrifugal switch, and ground out of the roll out switch.I am getting 24V to the gas valve on the "PV" wire coming from the pilot relay control. There are two other wires going to the gas valve that I am not sure of, but they do not have any voltage to the gas valve. they are labeled MV and MV/PV. I assume PV stands for pilot valve and should be at 24V, but what do the other stand for and should there be voltage there? I'm thinking I have a bad gas valve, but wanted to make sure before I go buy a 100 valve.
I forgot to say it is tring to light I can hear the "tick tick tick" from the igniter and can see the arc.
Thanks
Thanks
