’m working on a two rooms that were added on to the end of our house (included a diagram of 1 of 2, they are basically mirror images). We have a gambrel roof, and the rooms go all the way up to the rafters (there is drywall, not sure about insulation) and then near the side part of the roof there are vertical walls. The ceiling at the highest is about 12’ and from the side to side it’s also about 12’. The first room has the gable vent still there on the interior wall.
In order to get this first room to be usable, conditioned space I’m considering putting in a new ceiling to match the rest of the rooms on this level. I would just leave the drywall up on the rafters, wasn't sure if insulation there would matter. This would also leave the gable vent up in unconditioned space, and I could eventually duct that to the outside, if needed.
I was considering attaching a rim joist to the walls running around the perimeter of the room (I don’t know if rim joist is the right term here). Then I would be running joists across the room. In between the joists I would put batt insulation, recessed lighting or an overhead fixture etc., and maybe even rigid insulation on the bottom of the joists (saw this suggested on another site). Then attaching my drywall to the joists or furring strips underneath. This would mean I only have to put drywall on the ceiling (or maybe even a drop ceiling), not ripping off any walls. I'm going to check the exterior wall for insulation, and if there's none I was going to cut some holes and use blown in.
So, finally for my questions…
Does this make sense? What would be recommended lumber size? From what I found in code tables, I was thinking 2x6 for the 12' long joists, but wasn’t sure what size the rim joist should be. Couldn’t figure out how to look this up, since I don’t really know how to refer to it. Would 2x4 be enough? I would use lag screws to attach to the studs.
Should the joists sit on top of the rim joist or attach to the face? If I put the joists on top of the rim joist, I’m trying to figure out how to cover up the rim joist. Should I try and drop the level of the ceiling the height of the rim joist so that the drywall can run all the way to the wall? If I attach to the face, I’m guessing I would use joist hangers, but wasn’t sure if the drywall could just butt up against the bottom of the hangers.
Please let me know any other thoughts or suggestions! Thanks!
