Hello All,
The duplex is on a shared water supply. Any time two or more fixtures are being used at the same time the water in one becomes non existence immediately.
Each side of the duplex has its own full bathroom, water heater and kitchen sink.
The duplex is on a concrete slab.
I cannot find the shutoff valve (except for the city shutoff valve) or the prv (I'm assuming there's not one).
The water supply line is 3/4 and cutting a hole in the wall I discovered the lines feeding the fixtures are 1/2.
City has came out everything is good on their end and they place a pressure gauge on external tap and said its low
I checked faucet aerators
the 3/4 main supply is cpvc and everything else is copper
The water bill is not high so I assume there are no leaks
A plumber is suggest converting the lines that are 1/2 to 3/4 until it gets to the fixture. I am a newbie so i wanted to get advice before making pricey decision
Other Plumbers are suggesting to add a prv they said " this is usually the solution"
Again I am a newbie but if a prv is added that would only control the water pressure not increase it, correct???
Super Moderator
You are correct, the prv's are used for exactly that, reducing the high incoming water pressure. They can be adjusted from 50-70 psi. They come factory set at 55 usually. if you have low water pressure at your faucet a prv isn't going to increase it.
I agree with your plumber who recommends increasing the size of pipe to 3/4 inch, it will give you twice the flow which is what you need for the duplex so both families can enjoy decent water pressure.
Super Moderator
Cpvc and copper pipe usually don't get clogged. Old galvanize pipe does. Try the obvious things first like making sure all valves are fully opened.
From your statement, "pressure is fine until both families use it at once then it goes to half" sounds like a piping size issue. As your plumber suggests, main line should be 3/4 inch then 1/2 run off of that to your fixtures.
