Howdy,
I'm on a deep well, that goes into a pressure tank and I'm experiencing really low water pressure. For instance if the shower is going and I flush a toliet the water in shower almost completely stops, then starts back up a minute or so later.
I had the well pump and pressure tank replaced about 3 years ago, so I don't think its a pump problem.
The gauge says the well is pumping to 60 psi then stopping. Is that the right PSI?
Do I need to add more air to the tank with an air compressor? It has a Schrader value on top.
TIA
