We have an older home, but it was mostly re-piped back in the 1980's using copper pipe except in a couple areas which still use galvanized pipe. One of the old areas is the short section that goes through the foundation and supplies the whole house.
We have poor water flow/pressure all around.
I suspect that if we re-pipe just the galvanized sections with copper or PEX of the right sizes, we just might fix the problem. In other words, as far as I know, copper pipes are not susceptible to corrosion and scale buildup inside.
Anyone have experience with flow problems resulting from copper pipe? How much chance is there that there is restricted flow in the copper sections?
Thanks,
John in Kent, WA.
Thanks,
John in Kent, WA.
