On my desk I have 3 switches which control some fans on my PC. This plugs into the PC via a printer cable, as it has lot of wires for expansion. When I originally did this I did not really know much about the affects of down sizing wiring and how it creates lot of resistance. Well due to a fault somewhere I need to rewire this and I figured I should use some more serious wiring like at least 16 gauge vs the 30 or so that the printer cable has inside.
I'm just wondering, what would be the best way of providing a plug for this? Right now the printer cable's built in plug is how I can disconnect this to move the PC. If I go fully DIY on the wiring, is there some kind of standard connector I could use?
Worse case scenario I could use some plug ends but I rather use something different and smaller. I'm thinking like some kind of molex connector. Where would I find this?
Or I could maybe just use crocodile clips or something. As long as it can easily be removed. This is low voltage (12 volts at most) and there is short circuit protection on the PSU so if it shorts out it just shuts off, so as far as exposed wiring and what not there is not really any danger. Just need something that works.
