Have an LED neon strip it is 12v DC and has an A/C adapter is rated at 12v at 2 amps. The length of the strip is 6.5" long. Plan would be to cut off supply and hardwire in parallel to a single power supply rated at 12v 40 amps
Need to connect a total of 15 strips connected together on one power supply if possible
According to my calculations, each strip is consuming 24 watts.
At first, I thought I could wire everything in parallel and connect it to 120 A/C to 12volt power supply that is rated at 40 amps. However, I'm worried about the total length of the wire which is 6.5 feet x 15 = 97.5 feet
I guess my concern is how to address the voltage drop with this longer length and how large of a gauge wire will I need. Or would it be better to run lower amperage power supplies say 2 12v 20 amp power supplies.
