Hi Everyone. Just joined this chatroom to seek help with a water bang/plumbing/well pump problem that appears to be getting worse. Hope you can help!
We have a well, with a pump that is now 27 years old. The well fills a tank (blue) in the house, that has that bladder thing, and the well is set for 40-60psi (on/off). The bladder tank thing is about 15 or more years old. Our water is very hard and minerally.
It used to be (up to about a year ago) that when we came home from work (the house being dormant for about 11 hours), and turned the faucet on, or flushed a toilet, you'd hear a loud bang after a moment that seemed to coincide with the well pump going on (while the water was running). It would only happen the once after we got home. The sound came from the basement, and but closer to where the water enters the house, not near the water tank.
On weekends or other times we were home all day, it wouldn't happen.
Then we started hearing it more often, a couple of times a day, even on weekends, and now that we've been home for the last couple of months, it seems to happen several times a day.
I thought it might be a check valve at the pump in the well that was going bad, and allowing water to back into the well, filling the pipe with air that would then bang once someone ran water. I had someone from a pump company come out to look at it about a year ago, and they said the pump was fine (but didn't address a check valve at the pump - I don't even know if there is supposed to be one there). They changed the check valve at the tank in the house, and reset the bladder tank thing. It seemed to be ok for while, but now it's worse than ever.
I've looked for "water hammer" online, but everything addresses a loud noise when you turn the water OFF, and the noise happening then. This happens when the water is running.
I've read also that maybe the bladder is failing in the tank, but don't understand why it would bang like that.
Thank you, and hope you can help.
