1 - 6 of 6 Posts
Some how today I lost power only to all power outlets in my bathrooms.The lights all work just the outlets have stopped. I have a master bath with two outlets and downstairs bath with 1 outlet and a upstairs jack and jill bath with 2 outlets. Any suggestions to what I may need to do.
Electrician
A) Check the breaker box for a tripped breaker.
B) Check each receptacle, you might have one GFCI receptacle protecting every bathroom receptacle in the house. Check each one for a "Test" and "Reset" button. If you see those buttons, hit the "Reset" button (you might have to press it hard).
Thanks for the response man I have actual tried all those things and no power i will go to HD tomorrow and get a meter to test the outlets and wires.
Electrician
Some breakers are hard to tell when they are tripped. First I would "exercise" each breaker (this is good practice to do once a year) and switch them to the OFF position and then back ON. If that hasn't cleared the issue up I would go to the closest bathroom to the panel and pull out the receptacle and look for a loose wire. If you don't see a loose wire, this is where you need to test to see if you get voltage, but be careful because you will have live wires exposed when testing.
ok will do Proby thanks! its just funny how it just started plus I have been noticing that my outlets in the house spark when I plug things in them. could this be the cause of my outlets losing power.
Electrician
That's odd. The only time you should expect an arc is when you unplug a high current drawing device (motor, heater, etc.) without shutting it off first.
1 - 6 of 6 Posts
