I have a mosaic tiled floor and my shower drain is a bit loose. I can wiggle it a little bit with some effort. I don't know much about shower systems, but can I simply tighten the drain with the two the notches? Would that work, or is the drain likely mortared onto the pan? I want to avoid removing it should I put it back incorrectly. Like I said, it's just a bit loose and I'm worries some water will get in where the drain meets the tiles.
