1 - 8 of 8 Posts
Hi there,
The hot water faucet handle in the attached photo is loose. It's American Standard brand. I don't see any visible screws. I've tried shutting off the water and turning the whole thing counterclockwise, but it doesn't appear to come off (i got about 3/4 of a revolution)...do I need to just keep turning? It gets very stiff and I worry about causing damage to it.
Any ideas?
Thanks,
Hand E. Man
Retired Moderator
Look here and click on 'parts diagram 'http://americanstandardparts.faucetdirect.com/index.cfm?page=product:partsDisplay&productId=7881.732&manufacturer=American%20Standard
Retired Moderator
Sorry,link didn't take---American Standard 7881.732 Replacement Parts
There appears to be a cap cover on top of the handle--that hides a screw that goes into and adapter.
Be careful twisting that thing counter clockwise---you must hold the valve from underneath as you do that or you risk breaking off the water lines.
Retired Moderator
That doesn't even look like a cap----but the drawing showed it as such.
I use a pocket knife---close the drain! Don't loose the cap.
A lot of those faucets use the bell shaped base to hold the whole handle assembly together.
On moen the bell screws onto the valve body--Your counter clockwise attempt at unscrewing the bell was what I would have tried---Mike---
1 - 8 of 8 Posts
