1 - 6 of 6 Posts
Hi
I looked all over the code book but i couldnt find anything on loomex being in wiremold. I was just curious if anyone knows if there is a code about running 14/2 loomex in wiremold? Or does it have to be thnn wires? Im installing new lights and getting power from a plug. But the owner doesnt want to rip out the dry wall to add the power so i decided to use wiremold.
Thank you
Super Moderator
You can't strip the wires out of romex and use them but using the complete cable should not be an issue.
Property Mgt/Maint
Years ago I had a electrical inspector tell me I could not run Romex in wire mold. But more recently I have read on here that it is ok. Personally, my feeling is to run the THNN and know that it will pass muster
With some of the wire mold profiles, I would question if you can meet the bending radius with nm-b cable (US Romex) when going thru elbows/Tees.
I don't know the min bending radius on NMD90 (Canadian "Romex"/Loomex), but would still question it.
Using individual conductors, not a problem.
1 - 6 of 6 Posts
