Hi gang.
I have an old Delta shower control (see pic) and was wondering if there was a relatively easy way to convert it to a thermostatic temperature control. Anyone know if there is any type of drop-in faucet available? I don't want to have to remodel the bathroom just to make this change.
Thanks!
Murph
Exterior Construction
Best bet would be to call delta with the model number on your current unit and see what they say.
I wouldn't hold out too much hope as the cartridge units are totally specific to the body/housing and unless you want to open up the wall and install a new body, I think you are out of luck.
Start with Delta and see if they have any input.
What is on the back side of this shower wall?
I've seen valve bodies replaced from the rear. Less damage to repair and often in a closet so the repair is not as critical.
Do you have access to the valve through the back wall? Most newer name brand tub shower valves are ASSE 1016 compliant.
thermostatic or combination balanced-pressure/thermostatic valves that conform to the requirements of ASSE 1016 or ASME A112.18.1/CSA B 125.1 and shall be installed at the point of use. Shower and tub-shower combination valves required by this section shall be equipped with a means to limit the maximum setting of the valve to 120°F (49°C), which shall be field adjusted in accordance with the manufacturer's instructions.
