I'm trying to fill in some cracks in a built-in wood cutting board. One crack is 1/16-1/8" (2mm) wide by about 14" long.
I've seen recommendations to use Titebond Ultimate glue but looking up the specs it says to use only for "indirect" food contact, which means it "might come in contact with food, such as on the outside of food bag or carton." This is definitely a direct contact issue: the board is used for cutting foods, kneading dough, etc, so I don't think it would be a good idea.
The only things I can find that might be usable are epoxy resins; e.g., ArtResin specifically says it's food safe once cured. But the smallest amount I can get is 8 oz of resin/hardener (I'm going to only need like 2% of it) which costs $28 and is mail order only. By coincidence I've seen a bunch of the videos using resin for making neat looking chotchkas, but then I'd need a bunch of other supplies and, knowing me, that's a rabbits' hole I shouldn't run down.
Is this my only option?
