I'm having a heck of a time finding the part I'm looking for either at my local home improvement warehouse or online.
I need to fit together the 3/4" inner diameter PVC drain pipe from my air conditioner to the drain pipe that it was connected to (dumps to household plumbing). The pipe was sheared off due to physical force and it would cost me too much to replace the inner drain pan of the air conditioner. There's no water pressure to speak of, so leaks are not a concern. The drain emits about one drop per second at its maximum rate (that I've seen).
If I had a soft rubber, tapered, barbed, 3/4" inner diameter female-to-female pipe fitting, similar to the product at http://www.grainger.com/Grainger/LASCO-Coupling-6MM76 (picture attached), I'd be good to go, but I just can't find one made of soft rubber. I tried a hard plastic one but I couldn't get enough leverage in the tight space to get it into the plastic piping. Besides, I think the plastic piece is really for connecting two female flexible hoses together, not PVC piping.
Anyone know where I can find such a fitting?
Thanks,
Matthew
Thanks,
Matthew
