I am planning a boat dock project. We live on a bluff and have about 150' of steps to a small deck and are planning about another 50 to the boat dock.
I believe the boat dock would have a couple of 15amp /1hp lifts and few flood lights, a couple of 120 outlets and some low voltage lighting. I would also like to put some low voltage on the small deck. I am thinking 1 circuit for outlets, one for lights and 1 for the 2 motors.
OBTW, the hike to the deck represents about 6 or 7 stories of steps so a 3 way switch for some lights would be nice at the top.
So here are the questions I have so far:
I was planning on putting in a subpanel at the small deck which would later be moved/extended to the boat dock. Is 30amps enough? Can I do that on #6 or do I need bigger? What issues should I consider if I use aluminium (4-4-4?) for the run from main panel to the sub panel and run the circuits with 12/3 copper?
Is it enough to GFCI the circuit at the subpanel or do I need to put GFCI on each circuit as well?
I will contract an electrican to check my work and make the main connections but would like to go ahead and get the main run done ahead of time.
Thanks for any help,
Up a Creek
Up a Creek
