Hi everyone,
I've sort of been left high and dry with my heating system.
I built a new house 1 1/2 years ago and I installed a Luxaire heat pump. The guy's that I purchased the system from has split up and no one is taking responsibility for the system.
The problem is my aux. heat is coming on too often at warm temperatures. I done some research and found out that I can lock out my aux heat if I install an outside temperature sensor to a certain degree. My system is set up for two zones and I have two Honeywell Visionpro 8000's thermostats, model's T8320U. I have one outside sensor in which I hooked it to my main floor t-stat. The problem is that in going through the menu to option 340, option 2 isn't available. Only option 1, which is only an outside temp display.
Does anyone know what I have to do to enable option 2 so I can lock out my aux heat?
Thanks,
Tankmister
Thanks,
Tankmister
