1 - 7 of 7 Posts
I’ve just moved into a house built in the 1950s. Most of the wiring is fine but one outlet has an open ground. I saw this with my little outlet tester and I confirmed by measuring 121V hot-neutral, 9V neutral-ground, and 10V hot-ground. This circuit has 2 outlets total, and the other one is fine.
I removed both outlets, leaving the wires hanging free. Now I still measure voltage at both outlets, and the grounding hasn’t changed. How can the second outlet have a good ground if the first one is broken?
I thought outlets always run in a chain, so disconnecting the first one should kill power to the rest. Inside the main panel I can see this breaker has only one hot wire. There are no splices inside the breaker panel. So it seems like there must be another box somewhere I can’t find that splits the wire to these 2 outlets?
Super Moderator
Do you have two wire or wires in the box?
Has this house been rewired? 1950's was cloth wire and no ground for the most part. Have you looked at the other receptacles saying grounded? These 2 receptacles may have been added from an ungrounded source.
The box has one black, one white, and one ground coming in. Most of the cable sheaths do look like cloth, but every other outlet in the house includes a ground.
Not to say it is your situation, but FYI, back then kitchen metal boxes were grounded via a bare wire running outside of the romex box to box to a metal water pipe which could get disconnected during remodeling.
Discussion Starter · #6 ·
Finally I found what seems to be the good outlet upstream of this bad one. I’m thinking the easiest solution now would be to fish a new bare ground wire from one box to the next. I’m not sure if that is allowed or if I have to run a new 14/2 with ground.
A "Handy Husband"
Run a new cable.
Sent from my Lenovo TB-X606F using Tapatalk
Reactions: joe-nwt
1 - 7 of 7 Posts
