I have a 3/4 acre property with a 15 zone sprinkler system.
The zones seem to be grouped with 2 valves and wires per 'box' in
differently places around the yard.
My system has not been used / maintained on a regular basis.
For instance... 6 inches of soil was added to one area that is covered by
zone '2'. The sprinkler heads were just buried under the 6" of soil and
grass eventually grew over them. I discovered the location of the buried
heads by turning the water on and letting that zone run for 20 minutes.
I then walked around the area that that zone covers and found
the wet spots where the heads were buried and where the water was
trying to come out.
Now... the issue I have is that I've only managed to locate about 1/2 of the
sprinkler valve boxes.... The zones work ( mostly ) but I can't find the
valve box locations. There are a few zones with some issues and I really
need to find the valve box locations.
How can you find them if they are buried? ( I have a large yard.... poking
a hole every 6" in the ground won't work.... )
I don't want to spend a lot of $$$ to locate these if I don't have too.
Thanks - jack
trying to come out.
Thanks - jack
