1 - 9 of 9 Posts
The end goal is to utilize the vertical space in my 9.5' tall garage for storage. The garage roof has 4 large steel "rafters" at 8' spans and there are metal furring strips attached to the rafters and the drywall is attached to the strips.
The question is, how much weight can those strips hold? I'm contemplating screwing a 2x4 into the furring strips lengthwise and hanging shelves from them for long term storage similar to what Jackman did in this video:
Just not sure how much weight the furring strips can handle and don't really want it all coming down on my head.
Discussion Starter #5
I've been leaning that direction but I wasn't sure if I was just being paranoid. I've put all of my weight on the top sides of the strips just long enough to get from beam to beam I've been leery of their ability to support a long term load.
I do have access to the attic and if I remember right the beams are 4x6 "C" beams. I'm not sure of the gauge but I tried to put a joist hanger in one a while ago and couldn't get any kind of drill bit or self tapping screw to make anything other than a small dent in them so they seem fairly stout.
retired framer
Build a joist out of 2 2x4 one sits on edge on the drywall between the beams one above that but it sit on the beam on edge and join them together with plywood 1.2" set that in place from above and drive a few drywall screws from below so it stays put and hang your shelf to that.
When we build scaffolding and the supports are 8 ft apart we walk on 2x10s we test them at ground level first.
Discussion Starter #7
That's a great idea, thank you. Clarification question: in order for the top 2x4 to rest on both beams it would need to be a 10' board rather that a standard 8'. Would a 2"x4"x10', resting on its edge, be strong enough to support the shelf or would it need to be a 2x6x10? And when you mentioned plywood, was that half inch or 1.2in plywood? I like the idea and I'm planning on using it so I just want to make sure I have it right.
retired framer
Yes a 10 ft laid on the floor, a shorter one that fits between laid beside it.
The distance from the outside of the shorter to the inside of the longer will be the height of the beam and nail 1/2" plywood on them with nails ever 8"
I would trust that with over 500 lbs
The weak spot would be where the top 2x4 comes out of the plywood.
A bulge in the drywall would show long before failure so you could watch for that.
If you really want to load it up add another 2x4 to both after the plywood.
Discussion Starter #9
Thank you very much for your advice and suggestion. I'm certain I won't be loading more than 500 lbs on these shelves so a single joist should do it.
1 - 9 of 9 Posts
