Thank you for letting me join this forum. The load center pictured is an HOM612L100RB in which I installed the recommended ground bar (PK7GTA). The issue I'm having is I need to place a 3/4" terminal adapter on the lower left side but the ground bar is too close to allow the adapter to be mounted there. If I move the ground bar to the right side, then I'm facing the same issue on that side. Question: does anyone have an idea if I can relocate the ground bar to a different location (other than the two locations recommended by the manufacturer) and still be within code?
