1 - 13 of 13 Posts
no wall above its a bedroom, basement below. In the basement there is a steel beam running directly below it. There was never a door there. I found out the woman who lived here before cut the archway into it.
· Banned
Do you know which way the ceiling joists run?
If they run parallel to the opening not much of a problem
If they run perpindicular & rest on the wall above the opening then it could be a problem
Without a wall above you only have floor support for upstairs
If perpindicular you are carrying 1/2 of the floor load from each room on that wall
Joist are usually 16" OC, at worst you have 2 joists that land in that 27"
Are you sure they didn't put a header in above the opening for support?
· Banned
How long ago was it cut out?
Any signs of cracks in teh ceiling or walls
Is the fireplace wall an angled wall
I would not worry about it too much if there aren't any cracks
Without knowing if they installed a header, or which way the floor joists run I would leave it
· We pick these?
If you cut an 2x4x81" out of an 8' wall, what happened to the other 11-5/8"? 81" (81-3/8") is a cripple/jack length framing member found underneath headers of the 2x12 nominal type with double top-plate above. Am I missing something? Are you suspicious that the previous person did sub-standard work unpermitted or is there some problem you've noticed?
(says I'm a noob, yes to the forum... I'm a 13yr custom framer in the field)
just from the picture it looks like someone did a nice professional job but you really cant tell until you get up in their and take a look to see how it was put together but at this point I think I would go with Dave on this if you dont see any cracks or sagging I would leave it be.That is unless your wanting to take it out and close it up ,I personaly like archways and the way yours looks is nice it matches the window in the backround perfectly
1 - 13 of 13 Posts
