Hi
So we removed a 3 ft end(to left of doorway in pic) of a 6 ft load bearing wall and a chimney that was unused. Chimney was not bearing any weight. See pic below. Load bearing wall is wall to right of chimney. This is bearing due to ceiling joists lapped/sistered above it. There was an arched opening just to right of chimney so really the only full length studs supporting the joists was the one to right of chimney and those around the doorway. We built a new wall just 12" behind it and parallel. Even though this new wall is not underneath the lapped joists since it is very close will this be sufficient. There are really only 3 joists that would be unsupported. Span is just over 10 ft.
