So here's the situation. I am removing a load bearing wall where 2x8 ceiling joists overlap.
There was previously a flat roof on these joists so they are decked with plywood/osb. The plan is to provide support with temporary walls on either side of the wall to be removed, remove the wall, cut the joists and the plywood down the length of the wall to slide the (city approved) doubled 2x12 header/beam to make the beam flush with joists.
Then attach with joist hangers. My first question is, anything wrong with this plan? The span is 17'. There is no second story, single gable roof, pierling over two load bearing walls at apprx. the midpoint of the rafter span, no additional weight that the joists will be supporting other than the weight of themselves and insulation I guess.
My second question is, do I need to be worried about outward pressure on the exterior walls? If I cut through the joists, isn't this what is keeping the roof weight from pushing the walls outward? If so, what would you suggest doing to still be able to get a flush header? There are no rafter or collar ties or anything similar. Maybe add some of those before hand?
Attached are two pics, I can post more if need be.
Thanks!
Thanks!
