1 - 19 of 19 Posts
Hi-
In the process of remodeling bathroom and the original layout no longer works for us as there is a closet in the middle of the room that was poorly placed. We would like to remove this closet and open up the room a bit. After removing the sheet rock it appears that the closet is load bearing. The reason I think this, is because 1) the size of the header is way to big for a non structural wall, and 2) the wall is perpendicular to the ceiling joists.. (pictures to follow).
If in fact this wall is load bearing here is what I would like to do. I would like to create a half wall with a column. this will be the right side of the new support. Then I would like to run a beam (There is where I need some expertise) over to a new closet that will be framed. This beam can rest on the top plate of the closet.
If someone can take a look at the pictures below and let me know if this would work and what size beam I would need that would be great. Joists are 2x10 spaced 16"OC the span for the new beam will be a total of 38"
Discussion Starter · #9 ·
Im going to confirm they run through to the next wall and will attach some pictures. I remember looking up into the ceiling and seeing the joists stop maybe 12 inches after that closet wall. lGoing to remove some more sheetrock to confirm. Ill be back with an update. Thanks again
If the joist stops short of the outer wall, sister a joist that overlaps it by at least 3' and bolt them together. Make sure both are straight and not bowing down. New joist does not have to have a seat since it is ceiling only (let me make sure: no living floor above?). New joist should sit on the outer wall but not necessarily on the opposite bearing wall. The heavy header maybe was made with a scrap. It also sits mid floor that suggests it is not load heavy.
Discussion Starter · #17 ·
Thanks again for the time - really appreciate it. And ill def get the hanger nailed in
Carpenter: ok, last hanger.
Home owner: can i change the plan? I want a closet.
Carpenter: grumble...:smile:
Have to remove the ceiling drywall, nail the hanger in and that should solve your problem removing the closet wall. Try to cut the drywall so it is mid of the joist (could be a double joist beam) so repair is easier.
1 - 19 of 19 Posts
